11 years agoYou can see in the picture that you posted that the RAM is configured with both the inputs and outputs registered (see the little flip-flop symbols driven by the clock). This explains your 2-clock delay. I believe the input registers are always there, but the output registers are optional. Walk through the settings in the Megawizard and you should see a check box that will allow you to eliminate the output registers.
