8 years agoQuartus II Version & Build Numbers
Hi, I am trying to open a very old design build using # Quartus II # Version 9.0 Build 132 02/25/2009 SJ Full Version I get errors when I load the design using V9. ...
8 years agoHi,
after your reply I looked through some additional files/docs. It turns out that the design was initially designed using version 9.0 But the final design was done using version 12.1. (INITIAL_DESIGN / LAST_DESIGN variables) The design now loads correctly. Thank you for your assistance. Regards, Elwyn --- Quote Start --- Hi, Thanks for you reply. I have a very old database of a product that has been in production for a very long time. There is no one left at the company that worked on this project. The FPGA family is Cyclone III. I have downloaded the version of Quartus II specifically to re-load the design in the tool set it was generated in. The idea being that the database should just load with no issues relating to tools version. The only slight difference in the tool I loaded was # Quartus II # Version 9.0 Build 132 02/25/2009 SJ Full Version - database vesion # Quartus II # Version 9.0 Build 235 06/17/2009 SJ Full Version - the version I downloaded I assume that these commands should be ok since I am using the tool set version the database was created by? Is there any difference between builds 132 & 235? Regards, Elwyn --- Quote End ---
