10 years ago
Quartus II v15.0.0.145 Device Installer fails Cyclone IV install
I downloaded both Quartus v15.0 and the Cyclone IV (web versions) today.
I installed Quartus without problems.
Next I ran the Device Installer and it fails with the message "Unknown element Aria10_part1"
The link to Software Installation FAQs is broken.
I am using Windows 8.1 64-bit and the standalone device installer.
Am I doing something wrong ???
potedit: also fails to install max10 with the same error.
    --- Quote Start ---
    I have the exact same problem :/
    Can't install any device after installation of Quartus. I guess I'll have to reinstall. Devs doesn't read these forums? It's like three weeks since first report..
    --- Quote End ---
    I think you need to try the workaround mentioned in this post. It works on my side.
    Just Use the QuartusSetupWeb-15.0.0.145-windows.exe to install your device, then put QuartusSetupWeb-15.0.0.145-windows.exe and max-15.0.0.145.qdz (or other qdz files) in the same directory. Next, launch QuartusSetupWeb-15.0.0.145-windows.exe, install to the same directory that you had Quartus II installed.
    You can also uninstall your previous installation, then install Quartus and devices all together at the same time.
    You can submit a report to altera, they might provide you a patch for this before they released it officially.
    Workaround:
    1. Put the desired devices (xxx.qdz files) in the same folder as the Quartus setup exe.
    2. Uninstall Quartus v15
    3. Resinstall Quartus v15
    Solution:
    Request the patch from Altera Support. I have verified this works and it only takes a minute or two to apply.
    FYI Altera Support did indeed work with me despite the original (automated) email about requiring a valid company email address.
