10 years agoQuartus II v15.0 - driver name of triple_speed_ethernet missing
Hello, I started using Quartus II v15.0 along with Stratix IV GX development kit. I want to run a sample code - Simple Socket Server on it. I am using niosii_ethernet_standard_4sgx230 (https:/...
10 years agoTo avoid compatibility issue, it is recommended for you to use the QII 12.0 in which the design was created. 12.0 and 15.0 are few major release apart and I would expect significant changes which might cause the older design not working as expect.
