15 years agoMy little module board came in and I tested, with a shortened USB Blaster cable:
1. Series termination 2. A.C. parallel 3. Buffer stage On 2 and 3 my signals were clean as distilled water and I still had the same problem. My solution unfortunately is going to have to be the same as yours. I have to leave the JTAG RST line on my DSP pulled low to allow its TDO to float and I hit the test point tied to this to inject the USB Blaster TDI straight into the FPGA (second in chain). How annoying. I have lost my confidence in long chains with Altera equipment inline. The TI DSP seemed to handle the whole chain just fine.
