15 years ago --- Quote Start --- Did you ever get a resolution on this issue? I am troubleshooting a similar issue on a new custom board using 3 parts in the device chain, Vitesse PHY is# 1, S4GX180 is# 2 and MAXII1270 is# 3 in the chain. Any tips would be appreciated, if I don't have a solution by Fri we start drilling vias and adding wire-mods. --- Quote End --- Hey, not yet. I designed a little PCB to test out 'serial' and 'parallel' terminations as well as a third signal path using a buffer stage. Shortening the USB blaster cable did not fix it, but may be required alongside the termination methods I am going to test. I'll keep you posted. I expect the PCB to arrive in a few days.
