14 years ago
Quartus II v.11.0
Help, please.
When I try to compile some project using QUARTUS II v.11.0 or v.10.01 (web edition bouth) i get these messages:
Info: You have a valid up-to-date license
Error: Selected feature of TimeQuest Timing Analyzer is not available with your current license, or license does not exist
Error: Current module quartus_asm ended unexpectedly
Error: Quartus II Full Compilation was unsuccessful. 2 errors, 0 warnings
I use Wwindows xp sp3, with hardware which meets QUARTUS requirements (512 Mb of Ram)
There was no errors during installation process, I have tied to download License file and use it, to reinstall program, to install fresh coppy of windows and than QUARTUS... nothing helps.
I know that there is more threads on this subject, but there is no solution, so I ask again. I
Apologize for my English.
    I ASK AGAIN:
    What is FAE (field application engineer) username, and where to get it (need it for Talk back function)???
    I have uploaded some simple project which cannot be compiled by my Quartus.
    Konst: the QII Release Notes are normally delayed from the software release by a couple of weeks
    bosandzeros: if you don't work with an FAE you don't need to fill out that field. if you do you can just ask your FAE
    i don't think this is the root cause of your problem
    i am able to compile your design successfully with QII 11.0 64-bit Subscription Edition on Windows 7
    Even I can compile that project on my PC with QUARTUS v9.1, but i would like to find solution for problem with newer versions.
    I compiled it OK with Quartus II Web Edition 11.0:
    Total combinational functions 25 / 5,136 ( < 1 % ) Flow Status Successful - Sat Aug 13 23:26:26 2011
    Dedicated logic registers 14 / 5,136 ( < 1 % ) Quartus II Version 11.0 Build 157 04/27/2011 SJ Web Edition
    Revision Name Led_Blink
    Top-level Entity Name Led_Blink
    Family Cyclone III
    Total logic elements 25 / 5,136 ( < 1 % )
    Total registers 14
    Total pins 2 / 183 ( 1 % )
    Total virtual pins 0
    Total memory bits 0 / 423,936 ( 0 % )
    Embedded Multiplier 9-bit elements 0 / 46 ( 0 % )
    Total PLLs 1 / 2 ( 50 % )
    Device EP3C5F256C6
    Timing Models Final
    I know that you can compile it, problem is because I can't do it... So what could be problem with my program?
    There can't be anything wrong with your code, if I can compile it. You must have a problem with your Quartus II installation.
    I KNOW THAT PROBLEM IS IN QUARTUS II, but I don't have solution for QUARTUS II problem!!!
