14 years agoQuartus II time limited .sof file
Hi, when I try to program my FPGA...it appears a advice window about a limited time .sof file generation...as shown in attached image. I'd like to know how I have to behave... Regards
14 years agoHi,
well.. If you want to use your code after the evaluation time has expired, you need to buy the IP core implemented in your programming - otherwise you won't be able to programm your FPGA. If your evalution period has not expired yet, this is just a reminder ;-) Regards
