15 years agoQuartus II synthesis error
I am new to quartus design flow. i invoked .qpf file using quartus II(v9.1). it is giving the following error when i try to synthesis. the design is having nios II system also. Error: Can't find Memory Initialization File or Hexadecimal (Intel-Format) File /u2/design/Quartus_4_port_ethernet/epcs_controller_boot_rom.hex for ROM instance Error: Can't elaborate user hierarchy "nios_1:\nios_gen:cpu|epcs_controller:the_epcs_controller|altsyncram:the_boot_copier_rom|altsyncram_1s31:auto_generated" Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 145 warnings Error: Peak virtual memory: 324 megabytes Error: Processing ended: Fri Jun 17 10:37:45 2011 Error: Elapsed time: 00:00:19 Error: Total CPU time (on all processors): 00:00:17 It is giving some error in SOPC builder also. The following is the error message from SOPC builder. "can't find the modules ISP1362 and bus_interface_0". But it is available in the project folder.Please note am not created new project. I invoked the old one. can you please help on this. thanks in advance.
