9 years agoQuartus ii stuck at Analysis and Synthesis
Hi all! My compilation of the VHDL project is stuck at 40% of Analysis and Synthesis status for more than 10 hours. It just freeze there, no error. The program is still running since the timi...
9 years agoThank you for your help.
I do pick different architectures on the upper level for the corresponding memory, where I do the port mapping. The original version of my project is to input the data to each m_1 to m_50 in the testbench first, then do the sorting operation. It works fine but take long time to simulate. Thus I decide to cancel the inputting data process but add an mif file to each memory. Then I am experiencing this issue. Here is how I pick the corresponding architecture and the port mapping:
entity processor is
port(......);
end entity;
architecture proc_rt0 of processor is
component control_unit is
port(
ports for this component
end component control_unit;
component mem is
port(
clock : in std_logic := '0';
data : in std_logic_vector (31 downto 0);
rdaddress : in std_logic_vector (6 downto 0);
wraddress : in std_logic_vector (6 downto 0);
wren : in std_logic := '0';
q : out std_logic_vector(31 downto 0)
end component mem;
signal m1_data : std_logic_vector(31 downto 0);
signal m1_rdad : std_logic_vector(6 downto 0);
signal m1_wrad : std_logic_vector(6 downto 0);
signal m1_wren : std_logic := '0';
signal m1_q : std_logic_vector(31 downto 0);
for m_1: mem use entity work.mem(SYN0);--------------------------------pick corresponding architecture
begin
m_1 : mem port map(
clock => node_clock,
data => m1_data,
rdaddress => m1_rdad,
wraddress => m1_wrad,
wren => m1_wren,
q => m1_q
node_control_unit : control_unit port map (
-- other ports mapping
-- port connect to m_1
cu_m1_data => m1_data,
cu_m1_rdad => m1_rdad,
cu_m1_wrad => m1_wrad,
cu_m1_wren => m1_wren,
cu_m1_q => m1_q
end architecture proc_rt0;
architecture proc_rt1 of processor is
port(
component mem is
port(
end component mem;
for m_1: mem use entity work.mem(SYN1);--------------------------------pick corresponding architecture
begin
m_1 : mem port map(
data => m1_data,
wren => m1_wren,
q => m1_q
cu_m1_q => m1_q
end architecture proc_rt1;
Then I use the similar way to pick the corresponding architecture for the processor in the upper entity. After I do some research online, I found the following page on altera website to do the initialization ram with multiple mif file which is the case I need to do. But it use verilog HDL, I am wondering if there is any way I can do it in the same way with vhdl? https://www.altera.com/support/support-resources/knowledge-base/solutions/rd11172006_639.html (https://www.altera.com/support/support-resources/knowledge-base/solutions/rd11172006_639.html) Thanks again for your help!
