9 years agoQuartus ii stuck at Analysis and Synthesis
Hi all! My compilation of the VHDL project is stuck at 40% of Analysis and Synthesis status for more than 10 hours. It just freeze there, no error. The program is still running since the timi...
9 years agoMany thanks for your help.
My project is to design a device with 100 memory block using M20K memories on Stratix V chips. 50 of these memories, let's say m_1 to m_50, have a initialization file. The rest, m_51 to m_100, do not have mif file. The ram code I generated from the Wizard is shown as follows:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY altera_mf;
USE altera_mf.altera_mf_components.all;
ENTITY mem IS
PORT
clock : IN STD_LOGIC := '0';
data : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
rdaddress : IN STD_LOGIC_VECTOR (6 DOWNTO 0);
wraddress : IN STD_LOGIC_VECTOR (6 DOWNTO 0);
wren : IN STD_LOGIC := '0';
q : OUT STD_LOGIC_VECTOR (31 DOWNTO 0)
END mem;
ARCHITECTURE SYN OF mem IS
SIGNAL sub_wire0 : STD_LOGIC_VECTOR (31 DOWNTO 0);
BEGIN
q <= sub_wire0(31 DOWNTO 0);
altsyncram_component : altsyncram
GENERIC MAP (
address_aclr_b => "NONE",
address_reg_b => "CLOCK0",
clock_enable_input_a => "BYPASS",
clock_enable_input_b => "BYPASS",
clock_enable_output_b => "BYPASS",
enable_ecc => "FALSE",
intended_device_family => "Stratix V",
lpm_type => "altsyncram",
numwords_a => 128,
numwords_b => 128,
operation_mode => "DUAL_PORT",
outdata_aclr_b => "NONE",
outdata_reg_b => "CLOCK0",
power_up_uninitialized => "FALSE",
ram_block_type => "M20K",
read_during_write_mode_mixed_ports => "DONT_CARE",
widthad_a => 7,
widthad_b => 7,
width_a => 32,
width_b => 32,
width_byteena_a => 1
PORT MAP (
address_a => wraddress,
address_b => rdaddress,
clock0 => clock,
data_a => data,
wren_a => wren,
q_b => sub_wire0
END SYN
What i do is to adding new architecture code to it since I think the only different is the mif file, thus what I do is as follows:
LIBRARY ieee;
LIBRARY altera_mf;
ENTITY mem IS
PORT
END mem;
-- architecture of m_51 to m_100
-- no mif architecture
BEGIN
GENERIC MAP (
numwords_a => 128,
numwords_b => 128,
widthad_a => 7,
widthad_b => 7,
width_a => 32,
width_b => 32,
PORT MAP (
clock0 => clock,
data_a => data,
wren_a => wren,
q_b => sub_wire0
END SYN
-- architecture for m_1 with mif file
-- m1.mif
ARCHITECTURE SYN0 OF mem IS
BEGIN
GENERIC MAP (
init_file => "m1.mif", -- memory initialization
numwords_a => 128,
numwords_b => 128,
widthad_a => 7,
widthad_b => 7,
width_a => 32,
width_b => 32,
PORT MAP (
clock0 => clock,
data_a => data,
wren_a => wren,
q_b => sub_wire0
END SYN0;
-- architecture for m_2 with mif file
-- m2.mif
ARCHITECTURE SYN1 OF mem IS
BEGIN
GENERIC MAP (
init_file => "m2.mif", -- memory initialization
numwords_a => 128,
numwords_b => 128,
widthad_a => 7,
widthad_b => 7,
width_a => 32,
width_b => 32,
PORT MAP (
clock0 => clock,
data_a => data,
wren_a => wren,
q_b => sub_wire0
END SYN1;
I am not sure if this is what cause the problem. Or I have to create 50 individual entity using wizard? Thanks again for your help!
