8 years agoQuartus II Simulation Waveform Problem
Hi everyone, I am an undergraduate student currently having Final Year Project on FPGA design. I encountered a problem while trying to simulate the design in Quartus II Simulation Waveform. I ha...
8 years agoHi,
Apologies for the delay. Following steps are required to set the environment. 1.Under NativeLink settings, select the Compile test bench option, and then click the Test Benches button. 2. Click New. Specify testbench_1 as the Test bench name, and tb as the Top level module in test bench. 3. Under Test bench and simulation files, enter or select the testbench_1.v file, click Add, and then click OK. The Test Benches dialog box displays the properties of the testbenches in your project. Refer https://www.altera.com/en_us/pdfs/literature/ug/ug_gs_msa_qii.pdf Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
