11 years agoQuartus II Programmer crashes Win10
unfortunately I encountered a problem with Quartus II Programmer on Windows 10. The first programming works fine. However, if I restart Quartus Programmer or try to program a second time I get a BSOD. Same if I disconnect the Hardware. Fresh installation, all settings default. Quartus II Programmer 64-Bit 15.0.0 Build 145 SJ Web Edition BeMicro Max 10 USB Blaster Driver Version 2.12.0.0 usbblstr.inf 64Bit Windows 10 Professional 64-Bit Build 10240 Error: IRQL_NOT_LESS_OR_EQUAL Param 1: ffffe001`2c45eff0 Param 2: 00000000`00000002 Param 3: 00000000`00000001 Param 4: fffff802`0402b690 Caused by: hal.dll @ +15690 Crash adr: ntoskrnl.exe+14e2406 Replies
Windows 10 is not officially supported yet.
Raise a ticket via mysupport - Altera_Forum
Thanks for the advice.
I thought that someone else maybe had the same problem. I will raise a ticket. - Altera_Forum
Quartus programmer simply doesn't work on windows 10. Nothing can be done with it until Altera releases a supported version.
Temporal workaround:
VM with Win7 and full Quartus 15.0 installation (stand-alone programmer version 12.0 does not support my device). Shared folder in which the output files go. - Altera_Forum
Good idea, I'd probably do it with CentOS linux with programmer only because it takes less space on my overflowing disk.
My PC runs Win8.1 also crashed when programming Stratix V in Quartus Programmer. Interestingly, in V series only SV has the problem.CV and AV are ok.havent try with newer familiy yet
