Altera_ForumHonored Contributor15 years agoQuartus II on linux display problem hi! i have been trying to install quartus and got some problems. at first, i could not install it because of '&' syntax error. then i tried sudo bash ./setup command and got over it. but then no...Show More
Recent DiscussionsHighlight similar instances of a selected word fails when scrollingSolvedAutomatically added negative node for TDS output doesn't work with Agilex 5Design Space Explorer - *** Fatal Error: Access Violation at 0X000000001E19EB30Tensor block usageError (169008): Can't turn on open-drain option for differential I/O pin HPS_DDR3_DQS_N[1]
