12 years ago --- Quote Start --- Is there a way to avoid this difference? By the way, I am using 13.1. --- Quote End --- I'm not sure. This is a good question to ask Altera directly. File a service request with Altera. Create a simple project that you can use to demonstrate that the design changes for each synthesis run, and ask how to keep things from changing. Make sure your design is fully constrained (via a TimeQuest .sdc file). Cheers, Dave
