12 years ago --- Quote Start --- It should not be indeterminate, i.e., resynthesizing with exactly the same starting seed should yield the same results. However, --- Quote End --- If using postFit, the result will be different. I guess the starting point is a little bit different after each compiling. Is there a way to avoid this difference? By the way, I am using 13.1. -Tony
