Quartus II keeps crashing on Ubuntu 14.10
Quartus II will start on Ubuntu 14.10. And I've successfully programmed .sof file to Cyclone V. But, if idle for a few minutes, it crashes with the following report:
problem details Error: *** Fatal Error: Segment Violation at 0xffffffff00000000 Module: quartus Stack Trace: 0x214ed: addbyter + 0xd (curl.so.4) 0x22403: dprintf_formatf + 0xd33 (curl.so.4) 0x22a45: curl_mvsnprintf + 0x25 (curl.so.4) 0x216c2: curl_msnprintf + 0x82 (curl.so.4) 0x12646: Curl_failf + 0x126 (curl.so.4) 0x910f: Curl_resolv_timeout + 0x12f (curl.so.4) End-trace Executable: quartus Comment: None system information Platform: linux64 OS name: Ubuntu 14.10 OS version: 14 quartus ii information Address bits: 64 Version: 14.1.0 Build: 186 Edition: Web Edition Anyone having similar problems? Any solutions?22 Replies
It ended up crashing in spectacular fashion a couple of times (windows vanished) last evening during a signaltap session, so I'm giving up on 14.1 again for a while.
I would seek support but since Ubuntu isn't supported and I don't feel like taking the time to test this on Centos (some of the previous crashes were happening on Centos 6.5/6.6) right now, it probably will not provide any useful result. These published tweaks certainly helped get further than I had gotten before though. One thing that still bugged me is that wile I think it was only "warnings falsely classified as errors", the result of the DDR pin assignment script execution is a little discouraging. It throws a lot of red text up on the console. To anyone who has had success on Ubuntu, have you exercised the tools pretty thoroughly and things still seem stable or are you just doing compiles and aren't deep in yet? Lance - Altera_Forum
Since downgrading back to Quartus 14.0.2, as I reported in# 4 above, I have not gone back to Quartus 14.1, so I have not tried any of the reported fixes. So, sorry I can't help at the moment. I can say that Quartus 14.0.2 on Ubuntu has not crashed once, and I'm working a Cyclone V SoC FPGA, so I've been using all the Quartus tools: HDL coding, Qsys, TimeQuest, ModelSim, Pin Planner, Programmer. Also, SoC EDS 14.0.2 for embedded Linux App development has been stable under Ubuntu. - Altera_Forum
That is good to hear. I had done some work with the SoC EDS stuff last year but nothing lately; otherwise everything I've done with 14.02 has been fairly reliable. I'm on Ubuntu 14.04LTS and probably staying there for the time being. I have kept CentOS VM's running because I could never get the CV SocKit GSRD yocto stuff to build properly under ubuntu 14.04 (or 13.10?); I had success under 12.04. I didn't investigate it too deeply. I had higher expectations for enterprise linux (unrealistic perhaps) and the laptop hardware support was not good for me; Ubuntu on my main machines has been a pretty good working OS.
Hello guys. I have same problem with Quartus II in Ubuntu 14.04LTS. The error is
Program is crashed in 5-10minutes or when I compillng project. The patch http://www.altera.com/support/kdb/solutions/rd01272015_37.html didn`t help me. Can somebody help me, please? Thanks.Inconsistency detected by ld.so: dl-close.c: 762: _dl_close: Assertion `map->l_init_called' failed! - Altera_Forum
I've been running quartus 14.1 on Debian for some time now, and aftere having these crashes every 5 minutes i did som digging as well and found that they were curl related. So I unplugged the network - and crashes stopped immediately. Now, I run quartus inside a VMbox VM, and disconnecting the network interface of the VM does not affect the network capabilities of the host nor any shared directories between host and VM, so I find this a workable solution. So there appear to be two simple solutions: 1) remove libcurl.so.4 (more elegant, thanks Pinhedd) 2) unplug the network cable. regards, Theo --- Quote Start --- Hello guys. I have same problem with Quartus II in Ubuntu 14.04LTS. The error is
Program is crashed in 5-10minutes or when I compillng project. The patch http://www.altera.com/support/kdb/solutions/rd01272015_37.html didn`t help me. Can somebody help me, please? Thanks. --- Quote End ---Inconsistency detected by ld.so: dl-close.c: 762: _dl_close: Assertion `map->l_init_called' failed! - Altera_Forum
There is also this thread, that has a link to a patch (which I havent yet tried).
http://stackoverflow.com/questions/28538645/quartusii-14-1-0-debian-linux-crash - Altera_Forum
For what it is worth, quartus II v15.0 seems the smoothest out of the gate for me on Ubuntu 14.04 LTS.
I gave up on 14.1 a couple of times due to random crashes. 14.0.2 was quite stable for me but it had a couple quirks. 1) needed hacks to get modelsim to run... not painful, but annoying. 2) the integrated help wasn't working at all. I lived with that... 15.0 (downloaded today) has modelsim running out of the box with no mods, help launches a browser properly, it seems "zippy", and without changing any settings the compile time is down maybe 10% on my cyclone V project. There may be issues of course, but this is all pretty promising. -Lance - Altera_Forum
--- Quote Start --- For what it is worth, quartus II v15.0 seems the smoothest out of the gate for me on Ubuntu 14.04 LTS. -Lance --- Quote End --- Hi Lance: Can you check something in with your 15.0 build. I'm getting a hard hang when I try to generate a PLL for the Max 10 under Ubuntu 14.04 LTS. (Mega wizard starts, but hangs as soon as I try to change in input PLL frequency) I've tried all the fixes listed in this thread, but still get the ld.so error message. But that happens shortly after I start quartus. Quartus seems to run OK, but the megawizard hangs. (At least for ALTPLL) Thanks Pete - Altera_Forum
Pete, Funny you should mention it... I attended one of the max10 workshops a couple weeks ago and kept running into that.
It is a GUI bug. Right after you open the dialog, stretch the window out a little (drag a corner) and make it so scrolling is not necessary. For me, once I adopted that "use pattern", I avoided the crash. It slowed me down in the workshop something crazy though because of the way it would just hang. Hopefully I'm remembering this correctly. Let me know if that solves it -- sorry I didn't see your post until just now. -Lance - Altera_Forum
Thanks Lance.
When I attemped move the window then expand it the first time, it still hung, but I used the maximize button in the alt-pll window, and it worked as well as the windows version.. (Still quirky, in that when you enter numbers, you can not delete the last digit. so you need to first type in the new number then erase the old number) Email notifications seem to be delayed from Alteraforums lately. So I just saw your message. Pete
