11 years agoQuartus II keeps crashing on Ubuntu 14.10
Quartus II will start on Ubuntu 14.10. And I've successfully programmed .sof file to Cyclone V. But, if idle for a few minutes, it crashes with the following report: problem details Err...
11 years ago --- Quote Start --- For what it is worth, quartus II v15.0 seems the smoothest out of the gate for me on Ubuntu 14.04 LTS. -Lance --- Quote End --- Hi Lance: Can you check something in with your 15.0 build. I'm getting a hard hang when I try to generate a PLL for the Max 10 under Ubuntu 14.04 LTS. (Mega wizard starts, but hangs as soon as I try to change in input PLL frequency) I've tried all the fixes listed in this thread, but still get the ld.so error message. But that happens shortly after I start quartus. Quartus seems to run OK, but the megawizard hangs. (At least for ALTPLL) Thanks Pete
