13 years agoQuartus II JTAG Server Error Code 89
I've been trying to program my DE0-Nano for over an hour and a half now, and I am always getting an error when I press start in the programmer:
Info (209060): Started Programmer operation at Fr...
12 years agoThank you slacker, the usb rules you provided work fine with a 64-bit Fedora 19 setup! Problem was solved
--- Quote Start --- Here's one of the better threads I've seen: === http://www.ict.kth.se/courses/is1500/2011/swsetup/n2errors.html === UPDATE: To sift through the stuff on this site, error 89 means you don't have the correct permissions to the JTAG device on your Linux box/VM. I added the following to my USB rules (read the multitude of posts on this topic, but pay attention to what I've done as well...yours could be slightly different): ===# USB-Blaster SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6001", MODE="0666", SYMLINK+="usbblaster/%k" SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6002", MODE="0666", SYMLINK+="usbblaster/%k" SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6003", MODE="0666", SYMLINK+="usbblaster/%k" # USB-Blaster II SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6010", MODE="0666", SYMLINK+="usbblaster2/%k" SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6810", MODE="0666", SYMLINK+="usbblaster2/%k" === Cheers! --- Quote End ---
