12 years agoQuartus II Fatal Error: Access Violation at 0X000000000CCC75BB
I am always getting this Quartus internal error (see below) when I compile my project (on the step of analysis & synthesis), although no error or critical warning were given. Could anybody tell me a possible reason? Thanks a lot. --- Quote Start --- *** Fatal Error: Access Violation at 0X000000000CCC75BB Module: quartus_map.exe Lock in use: 9 Stack Trace: 0x175ba: SSC_UTIL:: perform_timing_analysis + 0x6bfa (TSM_SSC) 0x19532: SSC_UTIL:: perform_timing_analysis + 0x8b72 (TSM_SSC) 0xba99: SSC_UTIL::build_tdb_netlist + 0x2a9 (TSM_SSC) 0xd3ff: SSC_UTIL::initialize_netlist + 0x10f (TSM_SSC) 0x73bb7: sutil_write_flattened_tdb_netlist + 0xe7 (SYNTH_SUTIL) 0x403b8: sgn_qic_helper + 0x2f618 (synth_sgn) 0x10b88: sgn_qic_full + 0x198 (synth_sgn) 0x1297b: qexe_get_tcl_sub_option + 0x1f2b (comp_qexe) 0x15bad: qexe_process_cmdline_arguments + 0x5ad (comp_qexe) 0x15cc1: qexe_standard_main + 0xa1 (comp_qexe) 0x17b8: MSG_INITIALIZER::~MSG_INITIALIZER + 0x118 (CCL_MSG) 0x175c: MSG_INITIALIZER::~MSG_INITIALIZER + 0xbc (CCL_MSG) 0x3c04: MEM_SEGMENT_INTERNAL::free_interthread_delete_queue + 0x94 (ccl_mem) 0x2d20f: msg_exe_main + 0x8f (CCL_MSG) 0x1652c: BaseThreadInitThunk + 0xc (kernel32) 0x2c520: RtlUserThreadStart + 0x20 (ntdll) End-trace Quartus II 64-Bit Version 12.0 Build 178 05/31/2012 SJ Full Version --- Quote End --- cheers, B.H.
