12 years ago --- Quote Start --- I found the error. Some ports are declared in the qsys example as std_logic_vector(0 donwto 0) you need to define them as std_logic especially for mem_clk of the altmemddr. --- Quote End --- Thanks kakaboud! Your answer fixed the problem for me - DDR2 in a QSYS system with vhdl as top level. I had to change the top level pin and the QSYS component declaration to std_logic instead of std_logic_vector(0 downto 0). Cheers, Greg
