11 years agoQuartus II ECO Fitting error when setting the D5 delay chain
I want to change the delay value of D5 delay chain for an output pad in RPE. My device is Stratix V.
After changing the setting, when I execute "check and save all netlist changed", error occurs as following: Can anyone help me? Thanks. Info: ******************************************************************* Info: Running Quartus II 64-Bit Fitter Info: Version 14.1.0 Build 186 12/03/2014 SJ Full Version Info: Processing started: Mon Jun 15 09:55:02 2015 Info: Command: quartus_fit --read_settings_files=on --write_settings_files=off ts240x -c ts240x --eco Info: qfit2_default_script.tcl version:# 1 Info: Project = ts240x Info: Revision = ts240x Info (11104): Parallel Compilation has detected 8 hyper-threaded processors. However, the extra hyper-threaded processors will not be used by default. Parallel Compilation will use 4 of the 4 physical processors detected instead. Info (21077): Low junction temperature is 0 degrees C Info (21077): High junction temperature is 85 degrees C Info (171003): Fitter is performing an Auto Fit compilation, which may decrease Fitter effort to reduce compilation time Info (171062): ECO Fitter applying ECOs to previous post-fitting netlists Warning (171124): Timing-Driven Compilation is disabled - timing performance will not be optimized Error (14608): You have completed a Rapid Recompile incremental compilation. Please run the Rapid Recompile Fitter to re-iterate your Rapid Recompile incremental compilation, or run Analysis & Synthesis (quartus_map) to start a Full Compilation. Error (11802): Can't fit design in device Error: Quartus II 64-Bit Fitter was unsuccessful. 2 errors, 1 warning Error: Peak virtual memory: 2560 megabytes Error: Processing ended: Mon Jun 15 09:57:22 2015 Error: Elapsed time: 00:02:20 Error: Total CPU time (on all processors): 00:02:20 Error (293001): Quartus II ECO Fitting was unsuccessful. 4 errors, 1 warning1 Reply
When you set the D5 delay chain in the assignment editor, why dont you run the full compilation again? since the timing will be different for the IO anyway
