Altera_ForumHonored Contributor12 years agoQuartus II, disable .bak generation Quartus II has a bad habit of creating old .bak versions of files. How can I disable this?
Altera_ForumHonored Contributor12 years agoI requested them to add the option to disable that. Very annoying.
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
