11 years agoQuartus II crashing during assembler phase with Arria 10 devices
Hello everybody, I'm experiencing a problem during my VHDL design compilation during the "Assembler" phase when I choose an Arria 10 as target. I've tried to compile with two different VHDL d...
11 years agoYou should be able to run a "Full" Compile on design set up as other Arria 10 parts and it should automatically move to timing analysis after fit instead of moving on to Assembly. I've run 110(non ES) designs this way.
If you try to force it to do Assembly then I would have expected an error, or it to silently not run, but it might not have been tested for all cases.
