It's all about whether you're distro is using devfs or udev. I don't recall which CentOS 5 is. I'll look into and post again.
What do you get when you type "jtagconfig" from a properly setup shell? Cheers, --slacker - Altera_Forum
Hello, i am not at my job atm so i can't answer.
CentOS uses udev! Nioswiki told me to that: For RHEL5 or Centos5, Create a file named /etc/udev/rules.d/51-usbblaster.rules and add the following lines to it. Take note that after# USB-Blaster, all code must be in one line. # USB-Blaster BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001",MODE="0666", PROGRAM="/bin/sh -c 'K=%k; K=$${K#usbdev}; printf /proc/bus/usb/%%03i/%%03i $${K%%%%.*} $${K#*.}'", RUN+="/bin/chmod 0666 %c" Next, create an empty file in your home directory named “.jtag.conf ”. touch ~/.jtag.conf That's what i did. - Altera_Forum
--- Quote Start --- It's all about whether you're distro is using devfs or udev. I don't recall which CentOS 5 is. I'll look into and post again. What do you get when you type "jtagconfig" from a properly setup shell? Cheers, --slacker --- Quote End --- Hello, this is what i get: [aprado@localhost ~]$ jtagconfig Error (Server error) when scanning hardware ] Thanks - Altera_Forum
Hello can anyone give me an answer? This is kinda urgent.
Do you have something that looks like this in your /etc/fstab file?
If not, add it and do a "mount -a" following it and the usbfs filesystem should be mounted. Never have seen that particular error myself, but that's the only step that I see missing. --slackerusbfs /proc/bus/usb usbfs devmode=0666 0 0 - Altera_Forum
Did it, and when i do mount -a i get the following message:
[root@localhost ~]# mount -a mount: usbfs already mounted or /proc/bus/usb busy - Altera_Forum
I had a similar issue under SuSE 11.3, but it was not the same error message as you received. Here is my config and solution.
I added the /etc/udev/ rules file and created the .jtag.conf, but couldn't mount my USB blaster on a DE3 board. jtagconfig resulted in the following status message:
Here was my /etc/fstab configuration of usbfs:$ jtagconfig No JTAG hardware available ~/src/nios2de3 $
And here was the 'dmesg' output showing the device being correctly detected when I plug in the device:usbfs /proc/bus/usb usbfs noauto 0 0
mount -a wouldn't mount it, so I modified the usbfs line in /etc/fstab from 'noauto' to 'devmode=0666'. Then mount -a added the device. jtagconfig then read my USB blaster just fine. Hope this helps...usb 2-1: new full speed USB device using uhci_hcd and address 5 usb 2-1: New USB device found, idVendor=09fb, idProduct=6001 usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 2-1: Product: USB-Blaster usb 2-1: Manufacturer: Altera usb 2-1: SerialNumber: 91d28408
