Altera_ForumHonored Contributor15 years agoQuartus II Can't see the USB BLaster Hello i am using CENTOS5, installed the quartus in my home folder without any problem. But the centos isnt recognizing the USB blaster, what should i do? I tried everything that is on nioswiki....Show More
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
