10 years agoQuartus II-Byte Blaster Upgrade
Hello, We are currently upgrading from Win2K to Win7. We had been using Quartus II Programming application with ByteBlaster (parallel port). We believe the USB-Blaster will work but are not sure w...
10 years ago --- Quote Start --- Hello, We are currently upgrading from Win2K to Win7. We had been using Quartus II Programming application with ByteBlaster (parallel port). We believe the USB-Blaster will work but are not sure which version of Quartus to use. Which software product/version should we use? Thanks in advance Tim --- Quote End --- Hey sommertj, you can try USB Blaster II as it has faster programming time. Unfortunately it is not currently availabel at Altera's website. You may have to contact their FAE for more information.
