Info: Elaborating entity "altpll" for hierarchy "pll:inst1|altpll:altpll_component"
Info: Elaborated megafunction instantiation "pll:inst1|altpll:altpll_component"
Info: Instantiated megafunction "pll:inst1|altpll:altpll_component" with the following parameter:
Info: Parameter "bandwidth_type" = "AUTO"
Info: Parameter "clk0_divide_by" = "10"
Info: Parameter "clk0_duty_cycle" = "50"
Info: Parameter "clk0_multiply_by" = "1"
Info: Parameter "clk0_phase_shift" = "0"
Info: Parameter "compensate_clock" = "CLK0"
Info: Parameter "inclk0_input_frequency" = "20000"
Info: Parameter "intended_device_family" = "Cyclone III"
Info: Parameter "lpm_hint" = "CBX_MODULE_PREFIX=pll"
Info: Parameter "lpm_type" = "altpll"
Info: Parameter "operation_mode" = "NORMAL"
Info: Parameter "pll_type" = "Fast"
Info: Parameter "port_activeclock" = "PORT_UNUSED"
Info: Parameter "port_areset" = "PORT_UNUSED"
Info: Parameter "port_clkbad0" = "PORT_UNUSED"
Info: Parameter "port_clkbad1" = "PORT_UNUSED"
Info: Parameter "port_clkloss" = "PORT_UNUSED"
Info: Parameter "port_clkswitch" = "PORT_UNUSED"
Info: Parameter "port_configupdate" = "PORT_UNUSED"
Info: Parameter "port_fbin" = "PORT_UNUSED"
Info: Parameter "port_inclk0" = "PORT_USED"
Info: Parameter "port_inclk1" = "PORT_UNUSED"
Info: Parameter "port_locked" = "PORT_UNUSED"
Info: Parameter "port_pfdena" = "PORT_UNUSED"
Info: Parameter "port_phasecounterselect" = "PORT_UNUSED"
Info: Parameter "port_phasedone" = "PORT_UNUSED"
Info: Parameter "port_phasestep" = "PORT_UNUSED"
Info: Parameter "port_phaseupdown" = "PORT_UNUSED"
Info: Parameter "port_pllena" = "PORT_UNUSED"
Info: Parameter "port_scanaclr" = "PORT_UNUSED"
Info: Parameter "port_scanclk" = "PORT_UNUSED"
Info: Parameter "port_scanclkena" = "PORT_UNUSED"
Info: Parameter "port_scandata" = "PORT_UNUSED"
Info: Parameter "port_scandataout" = "PORT_UNUSED"
Info: Parameter "port_scandone" = "PORT_UNUSED"
Info: Parameter "port_scanread" = "PORT_UNUSED"
Info: Parameter "port_scanwrite" = "PORT_UNUSED"
Info: Parameter "port_clk0" = "PORT_USED"
Info: Parameter "port_clk1" = "PORT_UNUSED"
Info: Parameter "port_clk2" = "PORT_UNUSED"
Info: Parameter "port_clk3" = "PORT_UNUSED"
Info: Parameter "port_clk4" = "PORT_UNUSED"
Info: Parameter "port_clk5" = "PORT_UNUSED"
Info: Parameter "port_clkena0" = "PORT_UNUSED"
Info: Parameter "port_clkena1" = "PORT_UNUSED"
Info: Parameter "port_clkena2" = "PORT_UNUSED"
Info: Parameter "port_clkena3" = "PORT_UNUSED"
Info: Parameter "port_clkena4" = "PORT_UNUSED"
Info: Parameter "port_clkena5" = "PORT_UNUSED"
Info: Parameter "port_extclk0" = "PORT_UNUSED"
Info: Parameter "port_extclk1" = "PORT_UNUSED"
Info: Parameter "port_extclk2" = "PORT_UNUSED"
Info: Parameter "port_extclk3" = "PORT_UNUSED"
Info: Parameter "width_clock" = "5"
Info: Found 1 design units, including 1 entities, in source file db/pll_altpll.v
Info: Found entity 1: pll_altpll
Info: Elaborating entity "pll_altpll" for hierarchy "pll:inst1|altpll:altpll_component|pll_altpll:auto_generated"
Info: Quartus II Analysis & Elaboration was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 191 megabytes
Info: Processing ended: Wed Feb 29 19:25:29 2012
Info: Elapsed time: 00:00:05
Info: Total CPU time (on all processors): 00:00:02
