14 years agoQuartus II 9.1sp2 on Ubuntu 12.04
I need to install QII v9.1 sp2 on my Ubuntu due to compatibility problems with college, which has v9.1sp2. I downloaded the linux installer from the altera website https ://www altera com/download/software/quartus-ii-se/9.1 Extracted: tar xvf 91sp2_quartus_linux.tar Installed tcsh: sudo apt-get install tcsh Running install: sudo tcsh install (tried csh also) got: if: Expression Syntax. Any ideas?5 Replies
I think the installer only runs on bash (and sh on Ubuntu is dash, not bash)
And also IIRC before 10.0 the Linux version of Quartus was subscription only and you will need a valid license to run it. - Altera_Forum
Hmm... but my default shell is bash here =p...
And even with the license, it should run at least. I'll try v12 and see what happens - Altera_Forum
By "default shell" you mean your user shell I assume? The problem is that the installation script uses /bin/sh, assuming incorrectly that it is always bash. But on Ubuntu, /bin/sh now points to dash and the installation failed.
AFAIK Altera still hasn't fixed this, so you can try either to edit the script to make it use /bin/bash, or change your /bin/sh so that it points to bash. - Altera_Forum
I'm have this problem in my Debian Installation. The script uses csh, i installed csh, and when i try the installation, i have this message in STOUT:
$ ./install $ if: Expression Syntax. I'm trying install the Altera Complete Design Suite 7.2, in Debian GNU/Linux 7, Kernel Linux 3.16.0-4-686-pae, with csh version 20110502-2.1. Follow the excerpt of script: # !/bin/csh# Altera Tools Install Script . . . unalias * if ( $?QINST_VERBOSE ) then set expert_mode = 1 else set expert_mode = 0 endif if ( $?QINST_DEBUG ) then set debug = 1 else set debug = 0 endif . . . - Altera_Forum
Try to use the latest release version of Quartus since altera had fixed a lot of bugs there
