14 years agoQuartus II 9.1sp2 on Ubuntu 12.04
Hi, I need to install QII v9.1 sp2 on my Ubuntu due to compatibility problems with college, which has v9.1sp2. I downloaded the linux installer from the altera website https ://www a...
14 years agoBy "default shell" you mean your user shell I assume? The problem is that the installation script uses /bin/sh, assuming incorrectly that it is always bash. But on Ubuntu, /bin/sh now points to dash and the installation failed.
AFAIK Altera still hasn't fixed this, so you can try either to edit the script to make it use /bin/bash, or change your /bin/sh so that it points to bash.
