15 years agoWill download the Quartus 10.1sp1 and try it out,
was also wondering if there is anyhting to do with the license that is causing me this problem. The SOPC Builder build fine # 2011.05.22 12:49:38 (*) Starting Nios II generation # 2011.05.22 12:49:38 (*) Checking for plaintext license. # 2011.05.22 12:49:41 (*) Plaintext license found. but when i try and compile in the main program it is stuck at 1% compile & Analysis 4% Also when i looked into the project folder i found this in the generated module(please refer attachment) -- megafunction wizard: %Not a MegaWizard-generated file% -- GENERATION: DEFERRED
