Altera_ForumHonored Contributor16 years agoQuartus II 9.0 build 235; Parameter settings problem Hi All, I encountered with a wiered problem. When one of my verilog modules was not sysnthesized as State machine by Quartus, I checked the parameters settings created by Quartus for the State...Show Moremultiple-attachments.zip119 KB
Altera_ForumHonored Contributor16 years agoGot resolved!!! Overwritten parameter settings manually on block diagram. Wishes, Trinath
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
