18 years agoQuartus II 7.2 and Ubuntu 7.2 Gutsy Gibbon
Took a while, but after browsing many forums i got this to work, and figured i would post a quick howto.
I essentially followed this : http://nioswiki.jot.com/altera%20software%20installation%20tutorial%20for%20ubuntu.pdf with a few modifications. FIRST: the install script did not run b/c there was no arch command so: as root i echo "uname -r" > /bin/arch chmod 755 /bin/arch then back as a user i installed quartus, follow the link above, including the usb blaster stuff if so desired. but this still did not result in a working quartus install for me, so to work around the gui not working, or sometimes partially working i copied libX11.so.6.2 to the quartus/linux directory. i then also created a link to that file from libX11.so.6 Magically, the quartus gui would then work. the one change i made to the USB Blaster install is that i sometimes had permissions issues. i found that running a jtag service as root resolved this so.... my init file for jtag is ================= # !/bin/sh # ## BEGIN INIT INFO # Provides: jtagd_init # Required-Start: $syslog # Required-Stop: $syslog # Default-Start: 2 3 4 5 # Default-Stop: 0 1 6 # Short-Description: Start Jtag daemon # ## END INIT INFO . /lib/lsb/init-functions NAME=jtagd_init DAEMON=/opt/altera/7.2_sp1/quartus/bin/jtagd PIDFILE=/var/run/jtagd.pid test -x $DAEMON || exit 5 case $1 in start) log_daemon_msg "Starting JTAGD" "jtagd_init" start-stop-daemon --start --quiet --oknodo --pidfile $PIDFILE --startas $DAEMON pidofproc $DAEMON > $PIDFILE log_end_msg $? ;; stop) log_daemon_msg "Stopping JTAGD" "jtagd_init" start-stop-daemon --stop --quiet --oknodo --pidfile $PIDFILE log_end_msg $? rm -f $PIDFILE ;; restart|force-reload) $0 stop && sleep 2 && $0 start ;; try-restart) if $0 status >/dev/null; then $0 restart else exit 0 fi ;; reload) exit 3 ;; status) pidofproc -p $PIDFILE $DAEMON >/dev/null status=$? if [ $status -eq 0 ]; then log_success_msg "JTAGD is running." else log_failure_msg "JTAGD is not running." fi exit $status ;; *) echo "Usage: $0 {start|stop|restart|try-restart|force-reload|status}" exit 2 ;; esac =============================== Then there also needs to be an /etc/jtagd folder this needs a file called pgm_parts.txt that i copy from the quartus install quartus/linux/pgm_parts.txt i also create links to this from jtagd.pgm_parts & pgm_parts in the /etc/jtagd folder. If you want this to be setup as a jtag server, you can also place a jtagd.conf file in the /etc/jtagd folder with the password ============== # /etc/jtagd/jtagd.conf # # This file is written by the JTAG daemon when its configuration is changed. # If you edit this file directly then your changes will probably be lost. Password = "1234"; ================= Lastly, /proc/usb needs to be mounted, so you need to modify the fstab file to include /dev/bus/usb /proc/bus/usb usbfs defaults 0 0 On a side note, Compiz / Java have issues.. export these environment variables to get over it.. # fix for compiz / java AWT_TOOLKIT=MToolkit export AWT_TOOLKIT --dalon
