9 years agoQuartus II 16 standard version Crashed problem. HELP!
When i compile my project, the quartus always crashed at 95% of Fitter(Replace & Route). Then the pop up window says the quartus meet unexpected error. the error code is following: "wildc...
9 years agoThank you for your help. I am compiling my project in my university lab, I believe the software use the most updated version 16.1.
This issue happens at same point every time. I do not think this is due to out of memory issue, since the memory usage I check is only about half of the computer memory. I will try to use another computer to check if it works. Many thanks.
