12 years ago --- Quote Start --- Without the qsf file it's a bit hard to determine, but I'm guessing line 41 looks like: set_global_assignment -name EDA_TEST_BENCH_MODULE_NAME "VHDL_uppgift_4e_vhd_tst " -section_id "VHDL_uppgift_4e_vhd_tst " It looks like it doesn't like the -section_id's for these guys. Try changing the lines to: set_global_assignment -name EDA_TEST_BENCH_MODULE_NAME "VHDL_uppgift_4e_vhd_tst " set_global_assignment -name EDA_NATIVELINK_SIMULATION_TEST_BENCH "VHDL_uppgift_4e_vhd_tst " set_global_assignment -name EDA_TEST_BENCH_NAME "VHDL_uppgift_4e_vhd_tst " and see if it helps. Pete --- Quote End --- ----------------------------------------------------- Hi Anakha, tried your suggestion but still it did not work. Thanks for the help and time.
