Quartus II 13.1.0 - different file size of the rbf file generate with two different computer.
- 3 years ago
Hi, I think I found the reason that generate two different file size. It is because directory have of the initialization of memory have been set in wrong directory. That why in two different pc generate two different file size of rbf file. One of them cannot find the initialization file, therefore it have lower file size of the rbf file.
Thank you very much for giving me advise and solution in this.
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
