Quartus II 13.1.0 - different file size of the rbf file generate with two different computer.
- 3 years ago
Hi, I think I found the reason that generate two different file size. It is because directory have of the initialization of memory have been set in wrong directory. That why in two different pc generate two different file size of rbf file. One of them cannot find the initialization file, therefore it have lower file size of the rbf file.
Thank you very much for giving me advise and solution in this.
Normally there is quartus database file consisting information related to synthesis, mapping etc. the file should be named e.g. qdb (if im not mistaken) or just compile the desing from scratch. Also just to be clear that that to me seem expected output (diff env and machine, lead to diff map/route/fitt/) and there should not be a concern.
