Quartus II 13.1.0 - different file size of the rbf file generate with two different computer.
- 3 years ago
Hi, I think I found the reason that generate two different file size. It is because directory have of the initialization of memory have been set in wrong directory. That why in two different pc generate two different file size of rbf file. One of them cannot find the initialization file, therefore it have lower file size of the rbf file.
Thank you very much for giving me advise and solution in this.
In your design directory (ie, wherever your DESIGN.qpf file is located) there should be these directories (folders)
created after a compile:
- db
- incremental_db
- simulation
The last one is optional depending on your project settings. Just delete those three folders and their contents.
There are also a bunch of .rpt .summary .map .pin & etc files in your design directory, but they will just be rebuilt, they don't affect a compile.
- BoonChin3 years ago
