Quartus II 13.1.0 - different file size of the rbf file generate with two different computer.
- 3 years ago
Hi, I think I found the reason that generate two different file size. It is because directory have of the initialization of memory have been set in wrong directory. That why in two different pc generate two different file size of rbf file. One of them cannot find the initialization file, therefore it have lower file size of the rbf file.
Thank you very much for giving me advise and solution in this.
You don't say what OS/environment each of the computers is using, so hard to provide any constructive comments.
As a start, I would just reinstall the Quartus software from a new download on the 'bad' computer.
- BoonChin3 years ago
Hi _AK6DN,
I am using Window 10, another computer also using same window which is window 10, I have try to reinstall the quartus software, still does not change anything.
