14 years ago
Quartus II 11.1 Installation Hangs
I've tried running the online installer.
I've tried downloading the DVDs and then mounting them as files.
I've downloaded the separate exe files and running them.
As soon as I accept the terms and conditions and click next, the installer never responds, and just sits there forever. I have let it run for about an hour and a half.
It's a brand new machine that just has Windows XP SP3 installed.
I have the firewall turned off.
I have turned MS Security Essentials off.
It's a dual core AMD.
About the only thing out of the ordinary is that this machine came with a card reader that shows up like a bunch of floppy drives, making the hard drive show up as I:\.
Help !!
    Bob, I was going to suggest disabling the card reader in the device manager then re-booting to get the hard drive back to 'C:'. I have
    realised that all installation paths would be incorrect when the card reader is re-enabled.
    Can you re-assign the drive letters in the 'Computer Management' window
    (on XP Start -> Right Click My Computer -> Manage)?
    Nial.
    I'm pretty sure that re-assigning the hard drive would require a complete re-install of windows. Also, the BIOs on this machine does not have an option to disable the card reader. I would have to turn the USB off altogether.
    I'm really hoping that this late generation of the Altera installer is not so poorly written as to not use the environment variables that describe the system.
    I ran TCPview while doing an install, and verified that there are no network connections being attempted by the installer. Ever. The thread that is blocking in the installer is running a function called something like InstVerifyDriver.
    Altera ... ?
    i regularly install Altera tools to the D drive, but my C drive is the primary boot device
    can you try the command line installer? it might provide more debug information. instructions are somewhere on altera.com
    The command line installer worked.
    I had to extract the devices file first to an installer dir, then overwrite that data with the programs to get it to run.
    I'm guessing that I will have to overwrite the dir once again to install the devices.
    FYI -- The --net options fails to contact some URL at sw-depot.altera.com.
    As far as I can tell, that never has existed.
    oy vey, that's an internal server at Altera
    i have instructions on how to fix that
    I need to install 11.0, because of a bug in sopc builder.
    I'm using the executable files from the ftp this time.
    Trying the very same approach, but with individual product options, this is what I get:
    I:\11.0_quartus_windows>altera_installer\bin\altera_installer_cmd --help
    Usage: altera_installer_cmd.exe [options]
    Altera Software Installer command-line 11.0
    Options:
    --version show program's version number and exit
    -h, --help show this help message and exit
    -i INSTALL, --install=INSTALL
    Select which components from the Altera design suite
    to install. Multiple instances of this argument are
    allowed. Use --all for all components. Possible
    choices include: 'quartus' for Quartus II
    Subscription Edition; 'quartus_free' for Quartus II
    Web Edition; 'nios2eds' for Legacy Package: Nios II
    IDE / GCC3 Toolchain / C2H Compiler; 'dsp_builder'
    for DSP Builder; 'modelsim_ae' for ModelSim-Altera
    Edition; 'modelsim_ase' for ModelSim-Altera Starter
    Edition; 'programmer' for the Standalone Quartus II
    Programmer; Example: --install=quartus
    --install=nios2eds
    -a, --all Installs Altera Complete Design Suite; see --install
    for list of software installed.
    -f, --full Installs Quartus II Subscription Edition, MegaCore (R)
    IP Library, and supported device family files.
    -w, --web Installs Quartus II Web Edition Edition, MegaCore (R)
    -n, --net Perform a network based installation over the Internet
    (default if --source not specified)
    -s INSTALLER_DIR, --source=INSTALLER_DIR
    Specify the source directory for the installation
    files. Example: --source=d:\downloads
    -t TARGET_DIR, --target=TARGET_DIR
    Specify target or destination directory for the
    installed software. Example: --target=c:\altera
    --temp=TEMP_DIR Specify temporary directory to store downloaded files.
    Default is to use TMP environment variable.
    --proxyhost=PROXYHOST
    Use specified HTTP proxy in format HOST:PORT. If the
    port number is not specified, it is assumed at port
    80.
    --proxy-digest Use HTTP digest authentication with provided
    --username when connecting through specified proxy.
    --proxy-basic Use HTTP basic authentication with provided --username
    --proxy-ntlm Use NTLM authentication with provided --username when
    --username=PROXYUSER Specify username for authenticationg through specified
    proxy server.
    --password=PROXYPASS Specify password with provided --username for
    authenticating through specified proxy server.
    --program_folder=PROGRAM_FOLDER
    Specify program folder name for start menu shortcut.
    Default is "Altera".
    --remove_temp Option to remove saved installation files after
    completion.
    --no_space_check Option to skip disk space check.
    --gui Option to launch Altera Software Installer GUI mode.
    Requires a valid X display on Linux operating systems.
    This option is required when using --update.
    --download_only Option to download component installer only and
    install later.
    --update Option to update installed features of an existing
    installation. This option must be driven using the
    GUI, and requires --gui
    --allow_installer_feedback
    Allows Altera Software Installer to report
    installation statistics to improve quality.
    --force, --auto Assumes Yes on all interactive questions to automate
    installation sequence.
    --inspect Inspects installation to assist in trouble-shooting
    installation files. Writes debug data to target
    install directory specified by --target.
    I:\11.0_quartus_windows>altera_installer\bin\altera_installer_cmd -i quartus -t i:\altera
    11.0\ -s i:\11.0_quartus_windows
    ALTERA SOFTWARE INSTALLER (version 11.0)
    Error: quartus is not a valid product.
    I:\11.0_quartus_windows>altera_installer\bin\altera_installer_cmd -i 'quartus' -t i:\alter
    a\11.0\ -s i:\11.0_quartus_windows
    Error: 'quartus' is not a valid product.
    I:\11.0_quartus_windows>altera_installer\bin\altera_installer_cmd --install=quartus -t i:
    altera\11.0\ -s i:\11.0_quartus_windows
