13 years agoMy simulatin on alter-modelsim has run successfully --- I simply run it from .vwf file directly (there is a choice to run RTL simulation there). And I didn't define any testbench except a .vwf file.
Then, I changed the setting in EDA tool by using Modelsim from graphics mental. At the same time, when I run the simulation from .vwf file interface again, I choice Modelsim from mental graphics as my tool to run. However, the simulation still goes to the altera-modelsim. This problem also showed in the script attached. Does anyone ever use the student version of modelsim for such a simulation? Can this version of Modelsim be used in such a scenario, combing with Quartus II for the simulation? I am so confused here.
