12 years agoI noticed that it is not good practice to set partition and Logi-Lock to the gold_top module,
because its has many pins such as pcie, ddr2 etc. So I create separate small module which has only clock and reset input and global reset output. Now I can set partition and Lock the XY position to it. Which means gold_top module is free from partition and Logi-Lock. This is convienient when I use Signal-Tap II Logic analizer which requires large memory.
