12 years ago
Quartus Global Reset assignment
I am working on Quartus V13.0 sp1 on incremental compilation mode,
and use partition by bottom up way.
Sub modules are compiled in separate project then export / import to the top module.
My custom modules are interfaced to Qsys, and this problem is happening in custom modules only.
I can assign some global clock to same CLKCTRL_Gx in top module and sub modules.
But I can not assign global reset signals in same way.
It works in any sub modules, but when I merge all sub module to top module,
global reset signal name is changed automatically.
Please tell me how to fix CLKCTRL_Gx number for the reset signals.
Also I wonder if top module CLKCTRL_Gx and sub module CLKCTRL_Gy is different,
Are those clocks still physicaly connected together ?
//................ top module ................................................
set_global_assignment -name AUTO_GLOBAL_CLOCK OFF -tag BOTTOM_UP_SCRIPT_AUTO_GENERATED
set_global_assignment -name AUTO_GLOBAL_REGISTER_CONTROLS OFF -tag BOTTOM_UP_SCRIPT_AUTO_GENERATED
set_instance_assignment -name GLOBAL_SIGNAL_CLKCTRL_LOCATION CLKCTRL_G9 -to reset_cold_250M_
set_location_assignment CLKCTRL_G29 -to "altpll_ckio:......_pll1_clk[0]~clkctrl"
create_clock -name {ckio_in} -period 10.000 [get_ports {ckio_in}]
create_clock -name {reset_fpga_} -period 10.000 [get_ports {reset_fpga_}]
create_generated_clock -name {ckio_250M} -source [get_pins {pll_ckio_....|inclk[0]}]
-multiply_by 5 -divide_by 2 -master_clock {ckio_in} [get_pins {pll_ckio_a|.....|pll1|clk[0]}]
create_clock -name {reset_cold_250M_} -period 4.000 [get_registers {reset_cold_250M_}]
input reset_fpga_, ckio_in;
wire ckio_250M, ckio_125M, PLL1_locked;
reg reset_cold_250M_, reset_cold_250M_t;
altpll_ckio pll_ckio_a (.inclk0(ckio_in), .c0(ckio_250M), .c1(ckio_125M),
.areset(~reset_fpga_), .locked(PLL1_locked));
always @(posedge ckio_250M or negedge reset_fpga_) begin
if (~reset_fpga_) begin
reset_cold_250M_t <= 1'b0;
reset_cold_250M_ <= 1'b0;
end
else if (PLL1_locked) begin
reset_cold_250M_t <= 1'b1;
reset_cold_250M_ <= reset_cold_250M_t;
end
end
//................ sub module ................................................
set_instance_assignment -name VIRTUAL_PIN ON -to reset_cold_250M_
create_clock -name {reset_cold_250M_} -period 4.000 [get_ports {reset_cold_250M_}]
input reset_cold_250M_; // sub module
    I found the solution. The top module before export and the top module after import must be place in same XY location.
    In case of PLL global clock, top can be at any place, but for the global reset register, it must be put in the same place.
    I noticed that it is not good practice to set partition and Logi-Lock to the gold_top module,
    because its has many pins such as pcie, ddr2 etc.
    So I create separate small module which has only clock and reset input and global reset output.
    Now I can set partition and Lock the XY position to it.
    Which means gold_top module is free from partition and Logi-Lock.
    This is convienient when I use Signal-Tap II Logic analizer which requires large memory.
