WShep1
Contributor
3 years agoQuartus FPGA Development Software 22.1 Lite crashes in Signal Tap
I am using Quartus 22.1 Lite software. I has been working fine until I try to set the Signal Tap Trigger flow control to "State-base". When I set it to State-base instead of Sequential, the entire ...
SyafieqS
3 years agoI am checking this with developer and will let you know if there is any update.
May I know how urgent this issue is? Does it completely roadblock your development?
WShep1
Contributor
3 years agoSince this problem doesn't seem to be a problem in Quartus Lite 20.1.1, I am using it instead of 22.1. Hence, I am able to proceed with my development. However, as always, I want to be using the latest release of Quartus Lite.
Thank you for your assistance with this problem. I am glad to see that it is not my computer causing the problem and that I am not the only one to be witnessing this issue.
Bill
