WShep1
Contributor
3 years agoQuartus FPGA Development Software 22.1 Lite crashes in Signal Tap
I am using Quartus 22.1 Lite software. I has been working fine until I try to set the Signal Tap Trigger flow control to "State-base". When I set it to State-base instead of Sequential, the entire ...
SyafieqS
3 years agoWilliam,
Yes, I can see the issue, From the IPS, I can see the agent is requesting small design that replicate the issue and still pending from Robert. May I know if it is possible for you to attach it here for me to observe the behavior? This might be a valid bug but I need to check it.
WShep1
Contributor
3 years agoYou don't need to load a design to observe the crash. All you need to do is follow these steps;
1. Open Quartus
2. Open Signal Tap from "Tools" Menu
3. Change the "Trigger Flow Control" box to State-Based in Signal Tap
4. Immediate Crash
It is not necessary to load a design to get this to occur.
Bill
