Quartus FPGA Development Software 22.1 Lite crashes in Signal Tap
Is there any error message for the crash reported? Or it just crash and hang forever?
- WShep13 years ago
Contributor
Thanks for your response.
As the program is crashing a BLANK "Quartus Prime Problem Report" box appears momentarily and then goes away as the program continues to crash. When the program crashes, it just goes away. It does not "hang". It can be restarted with the same result over and over again. Even if I Reboot the computer and try again, I get the same result.
The sequence of events to cause the problem is:
1. Open Quartus
2. Open Signal Tap
3. Change the "Trigger Flow Control" box to State-Based
4. Crash
This problem has also been observed by the local Arrow FAE, Robert Polk of Phoenix Arizona, with his copy of Quartus Lite 21.1. As a result he has opened a Case with Intel - IPS has Created Case 00774316 - ARROW ELECTRONICS, INC - Quartus Lite STP [5003b00001jXjflx0]
Do you have a copy of either Quartus Lite 22.1 or 21.1 that you might try to see if you get the same result?
