WShep1
Contributor
3 years agoQuartus FPGA Development Software 22.1 Lite crashes in Signal Tap
I am using Quartus 22.1 Lite software. I has been working fine until I try to set the Signal Tap Trigger flow control to "State-base". When I set it to State-base instead of Sequential, the entire ...
sstrell
3 years agoChoosing Signal Tap from the Tools menu, even if there is no project, creates a new unsaved file (stp1.stp by default).
But in any case, not sure what to say at this point. I've never experienced an issue with this feature. Unlikely but possible: two bad installations of Quartus.
WShep1
Contributor
3 years agoThanks for your response. What version of Quartus are you using? I see the problem with 221 and 21.1 Lite on two different W10 computers. 20.1.1 Lite does not have the problem. Since I don't have a paid license, I can't check it with any version requiring a paid license.
