WShep1
Contributor
3 years agoQuartus FPGA Development Software 22.1 Lite crashes in Signal Tap
I am using Quartus 22.1 Lite software. I has been working fine until I try to set the Signal Tap Trigger flow control to "State-base". When I set it to State-base instead of Sequential, the entire ...
sstrell
3 years agoDoes it happen with every .stp file? If not, maybe the one you are using is corrupted.
If it happens with all .stp files, it could be a bad installation of Quartus. Try an uninstall and reinstall.
WShep1
Contributor
3 years agoI meant to say "Trigger Flow Control" box not "Target Flow" Box
