12 years agoQuartus forgets project is compiled after exit/restart
Hi, I am currently using quartus 14, though I had the same problem with earlier versions. Basically if I do a a part of full compile - e.g. analysis & synthesis, fitting, etc., and then sa...
9 years ago --- Quote Start --- This is still a problem in 17.0 three years later. Why? --- Quote End --- I worked it out to be related to signal tap. If ST is enabled then the project when opened forgets that it is compiled. With ST disabled it remembers perfectly well (unless the last time the project was opened Quartus crashed).
