James_B
Contributor
4 years agoQuartus Fitter Random Failing
I have a design for Cyclone VE that is about 90% full, and if I recompile the same design several times in a row, the design will intermittently fail on routing.
The router settings have been at Pe...
- 4 years ago
Choosing the performance option runs the Fitter "harder" to get better results. Even with minor changes, you're changing the initial seed used by the Fitter so the results can be different (including not finding a valid fit).
RichardT_altera
4 years agoI believe sstrell has help to answer your question. Do you need further help in regards to this case?
